I'm sure there's a 7mm silicon sleeve spiral core wire out there? Maybe petronics make? This stuff ain't resistive like the carbon string stuff, but it does have real good resistance to "leaks". Works like solid copper core wire, as far as your ignition is concerned. The big but being this stuff can be bunched together in the plug wire conduits, and not leak your spark to earth. It also prevents induction spark leap. With solid copper leads, the spark intended for the cylinder on its firing stroke, can "leap" via induction, to another plug lead bunched next to it, that has its cylinder not on its firing stroke. It's harder for the plug to fire under compression than it is to fire a plug under any other stroke. The spark energy will take the easiest path. With the spiral wound stuff, this induction "leap" of the spark is vastly reduced, practically to never, but doesn't have the resistance of the carbon string stuff, which is what we need for our vintage ignition systems (no resistance) with the close coupled plug lead terminals in the caps, and small rotors and the like.
These spiral wound leads in 7mm are perfect for us, and will fit easy, unlike the 8mm stuff, and come in black.
If they were available in authentication color cotton braid, it'd sell like crazy. I don't know if it is though. One of the vintage specific hotrod speed shops may be a good call.
Martin.
