G'day 99! If that new Brassworks did not fix the problem...How long has it been since you changed your head gasket? We're suppose to torque them cold, once a year and most of us don't. I wonder if yours is loose or has failed...often a bad gasket does not give any evidence...yet when you pull the head, the gasket is toast! At that point, flush the block and the head...radiators often get blamed for things they did not do! Ask me how I know...Ernie in Arizona
I think you will find that the Radiators that Snyders's and Bratton's sell (unless they state Brassworks) are most likely provided by Independent Antique Radiator Mfg. Inc. http://www.oldradman.com/ they list them as distributors, and the descriptions match up. I walked thru their facility in Algonquin Il. high quality, hand made, awesome radiator...
What's seems to be the general consensus regarding the currently available replacement radiators for a '29 P/U as far as fit & efficiency ?
My Berg's is amazing. I have had it out on 100* days, and it barely reaches operating temperature. Their's is also the only one with cast bronze hose bibs. Mine is in a 29 RPU. I'm thinking of using a thermostat to get the temp up in cooler weather. Expensive, but cooling is the number one priority for having an enjoyable ride.
Bergs is the best.
It will outperform a Snyders HD (brassworks) all day long. You will pay a little more for Bergs, but there is a reason for that.
