Juggler
BRIERLY head. didnt know there wa one. Tell me more or where on facebook do I look. ken
Here's mine
7 to 1So if you stick this head on a bone stock 40hp engine, how much of a boost in hp would you get?
Boosting power and efficiency is a sum of all parts,the head alone will help but to gain maximum return matching carburetor flow rate to engine flow rate,increasing cam lift and duration,providing engine rpm controlled timing and increasing exhaust flow along with the compression increase from the head yields results..and yes,RED is a proven secret of speed,it goes faster,runs cooler and gets more chicks..![]()
Adding compression and a bigger carb are the quickest and easiest ways to more power. Hard to beat a Winfield, unless it is a BRIERLEY head. I'd post a pic but posting here is too complicated for my old brain. Facebook is much easier. A Stromberg 81 is much better than a stock carb, a 97 is even better.
