Hey Folks - What would cause a 90-degree bend in the rod? It was found laying in the valley of the block. Looking for advice to ensure this issue wont come up again when the motor is fully rebuilt.
Background: Craigslist bought motor so who really knows the history... The gentleman indicated it was pulled from an F1 when it started 'running rough'. To the naked eye everything is looking pretty up for this old worn out motor aside from two frozen valves and an excessive amount of oil sludge. The one drastically out of place piece I've observed was this fuel pump push rod that has a 90 degree bend in it... There is a kink about 1/4 of the way up and a 90-degree bend in the middle of the rod. The bottom 1/4 of the rod appears pretty clean (probably sat inside the camshaft guide) top 3/4 covered in buildup. I suspect the reason the rod was laying in the valley is because the manifold was previously removed (one bolt was extracted).
I'm of the impression this bend was man made (disgruntled owner trying to pull it out). Either way I'd like to try and solve this mystery to ensure I'm fully comprehensive in the rebuild. Any suggestions to ensure a rebuild doesnt result in another bent rod would be appreciated.
