David J
After seeing bugsiegels post I will address this . CALL the folks that made the system you have . Best source of good info you will find . I used to have a " Buske " floor pod system and I simply called them for advice on how to do this . If I remember correctly it is a grid of 8 holes in a rectangular pattern with 4 holes in two parallel lines . To respond to your last post the measuring of a frame is real basic - simple stuff IF you have a FLAT platform to measure heights off of . There is a reason ALL GOOD circle track car shops have a chassis plate for measuring heights from . Expensive but the ability to ACCURATELY measure heights is critical . If you are SURE the height AND cross-diagonal dimensions are good Some of the above advice will help with fixing the cosmetic issues with your frame . When you are done dealing with the cosmetics CHECK ALL DIMENSIONS AGAIN !!!!!!!
I am considering fixing my 34 frame myself. I know most will suggest taking it to a frame shop . I am thinking about putting some anchors in my garage floor to hold the frame in place . Has anyone done this with any success and if so, how many did you put in and how did you space them ?
