Brake Tips.
When I replaced brake shoes at work I always grabbed the parking brake cables and pulled down on them to make sure they locked the drums. If the cable movement seemed excessive I'd tighten up the adjustment before letting the lowering vehicle down on the hoist.
When you have assemble your brakes its always a good idea to grab the bottom of the shoes and forcefully pivot them back and forth and pull them towards yourself. This makes sure everything is hooked in well. It also proves the shoes will be able to self energize properly.
Put a little white lithium grease or brake caliper slide grease (preferred) on the backing plates where the shoes contact them. This helps them slide and prevents the backing plates from getting worn in those spots. Without the grease the shoes will eventually wear deep grooves in the backing plates. Then the shoes can get hung up in those grooves. To save the worn backing plates I use to weld up the grooves and grind them smooth again. They will never wear out if you lube those spots
Make sure the backing plate bolts are tight. Every once in awhile I would find some loose bolts. Loose bolts can wipeout the backing plates because they try to rotate during stops. This elongates the bolts holes, shears off the bolts and cracks the backing plate.
We had so many broken brake springs in the fleet at work that when they got to be around five year's old I replaced all of them when I did a brake job. You have them off anyway and they are not very expensive. That just about put an end to broken brake springs.
The number one mistake people make is installing the shoes backwards. If you understand why the longer shoe always goes to the rear on "self energizing" brakes it will help you remember that the long shoes goes towards the rear. Because of the self energizing action the rear shoe does more work than the front shoe. So the rear shoes will wear out at the same time as the front shoes the rear shoe is "usually" thicker. There are vehicles where the shoes are the same length. If there is a thicker shoe it would go to the rear.
People that have been taught that the long shoe always goes on the rear make the mistake of installing the long shoe to the rear on Early Ford hydraulic brakes. They are the opposite, the long shoe goes to the front. Its because of the way the shoes are anchored at the bottom. More force from the rotating drum is applied to the front shoe. The front shoe is called the 'forward braking shoe' and the rear shoe is the "reversing shoe".
If the brakes have self adjusters use your thumb to push on the cable to make sure it rotates the adjuster. A lot of times you need to bend the plate that contacts the adjuster to make sure it engages the teeth and rotates it. . Grease the threads on the adjuster.
Never grab the springs with a pair of dikes. You will leave marks that will cause the springs to break in those spots. There are two tools that make a brake job easy to do. brake spring pliers and the tool that pushes down the brake shoe hold down springs. Both tools are cheap. They make job so easy, especially flipping the springs off (see video). You can find them at garage and estate sales. I have a bunch of them I've paid about $2.00 each. I sure all the auto parts stores carry them but they won't be the quality of the ones made in the 60s and 70s. Proto made nice ones.
YouTube video showing how to use brake spring pliers. Unfortunately, this is the best video I could find (Chevy guy). I disagree with using the vise grips on the hold down springs but it does work. The tool with the black handle is a better choice.
https://www.youtube.com/watch?v=MIyESaecC2s
I prefer the Ford caliper slide grease available at a Ford Dealer. The Permatex is good too. All the parts stored should have it. A tube will last you and all your gearhead bubbies that borrow it a lifetime.
