John Voelkel
several years ago I changed the brakes on my 1941 Ford to the Bendix style. I understood that for the conversion to work best I had to center the brake assembly in the drum. The procedure to do this was to loosen the large bolt on the rear of the backing plate and then adjust the brakes until the wheel would not turn. Then tapping on the backing plate until the wheel would turn, adjust the brakes until the wheel would not turn.
Keep repeating this until no more adjustment was needed. This worked great on the right side but I was not sure about the left side. If the brakes are adjusted up rather tight there is no problem but after there is some wear on the shoes, the car will pull to the right when the brakes are applied hard. Am I doing this ok? With the large nut at the rear of the backing plate loose why doesn't just stepping on the brake pedal cause the hydraulic pressure center the shoe assembly?
John in Baltimore
John in Baltimore
