bellcrank
vernon
Hello guys,
Just install a Tatterfiels manifold with a Stromberg 97 carb. I now need a bell crank. Is there one being made.
Thank you Carig. I saw a die cast on e-bay but can't seem to fine it now.
Pictures of yours would be helpful.
Here's a picture of one that was on Epay.
Bob
One can be easily made from aluminum or steel stock. There is no need to have an angle in it as pictured above. Make it longer than needed so you can adjust the length from the pivot point to suit your needs and be certain the carb fully opens.
Thanks to all for suggestion. problem making one is the throttle ball .I have look all over for them with no results. Any suggestions?
