Hi can anyone tell how much bearing crush for mains and con rods engine is 8BA any info welcome
I believe it should be 0.004 - 0.005
I have read the instruction that come with the bearings no mention of crush checked most of my books can not find anything
If you are attempting an online search, the word "crush" may not turn up what you are looking for, the normal specification term is "clearance". .004 - .005 would be way to loose. By the way, these numbers are normally given in inches, not millimeters (sure you already knew that, but just to be on the safe side). Think 4tford has the correct clearances and I agree, check it with plasti gage.
Crush and clearance are two different things, not different names for the same thing,
If you want to find out about bearing crush, look up bearing crush. It's where the bearings are slightly over half the Rod or main bore. They sit a tickle proud of the caps before torque down. When you torque the cap, the bearing shell is forced hard into the bore, making it fit real good.
This is a simplified explanation. To show that it's different to clearance.
Martin.
I used to cut bearings for years back in the 60-70 we used to get semi bearing and could cut any size you wanted, the bearing are about .001 thinner on the sides then in the middle, when you torque them down in the block or rod cap they squeeze together or crush. You can't check that with plastic gauge you have to use a mic. If you talking about clearance .002 is about right for a stock engine. My brother used to go out on the road and turn a rod journal on a truck that had spun a rod bearing with a portable crank grinder, he would call me with what size and I'd cut a bearing to fit it. That's a dead occupation now. Walt
I have been rebuilding engines for over 50 years and that is the first time I have heard crush used that way (or if I have I forgot, which is more likely). I understand what it is, just never thought about it. Because main caps or rod caps are torqued to spec when they are bored or honed to final size isn't it automatically taken care of? Seems like this would be an engineering factor that would be designed into the IDs and bearing sizes, correct?
