If using a Model B distributor on a Model A with a Model A timing cover, can one use the B distributor as-is or does the distributor need to be modified in any way to get the proper advance?
I have examined this thought in answer to my question of the Gordon Smith interest I cite up at reply 11.
The easiest way to put a Model B distributor on a Model A would be to change out the front cover and replace it with the Model B cover.
Currently there are two covers listed on Ebay which report to be Model A covers, but are in fact the Model B cover. One can tell from where the timing pin hole appears relative to the casting boss. Not too expensive on either of these, you pay almost the same for the cover as for the shipping.
AND - if one is talented and pretends to be a machinist, one can find "aftermarket replacement covers" made by Ford which can be drilled for either the Model A or the Model B. This would be the A-6019-BR cover. There is one of these on Ebay currently which is drilled for the Model A but to which a second hole could be added for Model B. Available again for small money.
See Vince Falter at
http://www.fordgarage.com/pages/timingcovers.htm for how to identify which cover is which.
The 9-1/2 degree difference between the two marks is "intrinsic" in the distributors and relates to where they start the engine in "full retard." Model B distributor starts out "later" at full retard than the Model A distributor. (Ford perhaps realizing that by the time of the Model B, car users were mostly using the electric starter rather than a hand crank) And advances with increasing speed automatically, but does not advance as much as the manually advanced Model A distributor is capable. (Ford perhaps realizing that full "super advance" is NOT where the engine is most efficiently operated.)
Vince Falter addresses the differences in timing quite nicely and the reasons why at
http://www.fordgarage.com/pages/bdistributoradvance.htm
There is a Model B distributor currently on Ebay for medium money which has a damaged tang. Were I to modify a Model B distributor to work directly on a Model A I would start with this one and weld up and re-machine the damaged tang to 9-1/2 degrees difference. This WOULD be a job for a machinist - assuming he has enough of the original tang to "get a read."
Note that one CAN use a Model B distributor with the Model A cover. Starting would still occur at the "full retard" just as it does with the Model A distributor. But the problem comes with increasing speed - the Model B distributor will not match advance properly to speed and will always be "retarded" (in a timing sort of way) and not operating at the most efficient match between advance and speed.
AND - that 9-1/2 degree difference still exists in the point-plate locations at full retard. As I say, the difference is intrinsic.
I marvel at some of the research done by Vince.
Joe K
