Resistance creates heat-thats what makes a toaster work!,but it will pull a battery down fast,If you have the clamp-on type of terminals on the cables,get rid of them as they are only a band-aid fix & are prone to get corrosion under them.If you lift the cable off the battery & there is a spark,then you have a current draw somewhere.If grounds are good,then I think the battery is shot.
