Will N
Just got my '15 Touring delivered on Sunday. What a blast to drive! It's such a different experience from any other car I've driven. Anyway....
There is no starter in this car. There's a 6 volt lead/acid storage battery under the rear floorboard used for powering the ignition while crank starting the car. The positive terminal is wired to the post on the coil box, the negative is grounded to the frame (is that right, or is the polarity reversed, or does it matter?). The wires seem to be a home-made affair, and aren't in too good shape. I've looked in Snyder's and Lang's catalogues, and they don't seem to list any battery wiring harnesses for pre-starter cars. Should I just make my own replacement?
I also saw this thing called a Hot Shot. Looks to be a small battery for starting that gets recharged from the magneto. Sounds like a good thing, as I'd have to keep a trickle charger on the storage battery to keep it fresh. Anyone have any experience with this Hot Shot product?
Thanks
Will
Thanks
Will
