This may start a row AGAIN, but the safe place to put it is in the ground lead, not the "hot". Be advised, a cutoff will not turn off a running engine, it only disconnects the battery. The engine will continue to run off the generator.
Mike, I like that idea and plan to do it. Could you explain the "plastic plate" part of the instructions and also why (or how) the second lead goes to the battery ground side AND the ****** cover bolt? Thanks. Bob
Under hood could be to late.I have a 28 sport coupe that has a metal seat riser. I put mine in the front of the seat riser you cant see it! I ran the cabled thru the floor and put rubber grommets in the holes to prevent chafing.PCV valve grommets work great. i wasnt going to put one in until a short caused smoke to come blowing out of the instrument panel! i changed my mind quickly. I do agree that those mounted under the hood look terrible. You cant see mine!
I like the knife type break no break.I have a 28 sport coupe that has a metal seat riser. I put mine in the front of the seat riser you cant see it! I ran the cabled thru the floor and put rubber grommets in the holes to prevent chafing.PCV valve grommets work great. i wasnt going to put one in until a short caused smoke to come blowing out of the instrument panel! i changed my mind quickly. I do agree that those mounted under the hood look terrible. You cant see mine!
I mounted mine off the starter with the bracket that the A vendors sell...and yes I have to open the hood to turn it on and turn it off.
That gives me a chance to look over the area for anything that looks out of place and to give the engine a once over.
I do not drive the car every day so this MAKES me check out the engine area before and after each trip/ride/etc.
I dont like cutting un necessary holes in any of the car so this way I didnt have to.
Dennis L Oberer
Green Bay WI
