Battery posts
bunnyc
I'm aware that the positive and negative posts on batteries are different diameters. Positive is larger than negative. This causes a slight problem with positive ground systems. Battery cable clamps are sized for the more common negative ground system.
On to my experience today; came out of Lowe's to a no start situation. Step on the starter and there was silence. My first thought was to check the battery cables. Sure enough the cable on the negative post was loose. The clamp bolt is tight, but I was able to twist it slightly on the battery post and it started right up.
Got home and installed a sheet metal screw between the clamp and post to secure it as a temporary/permanent fix.
Maybe the vendors have a cable with the proper battery clamp; I'll check.
I could also remove the present cable and grind off some of the lug so the bolt will tighten the clamp on the post.
I mention all this in case someone else has a similar experience. Check the easy things first.
Kinda common.. Sometimes one can remove the bolt and hacksaw a slot where the clamp has come together to gain enough gap for proper 'clampness'.
The farm N Fleet battery i have the temp positive cable im using (store bought universal red battery cable) fits on the neg post snugly and the braided cable fits on the neg post tightly.
But yes those caps posted above will work but be aware they can corrode underneath and have weird no start issues.
Yep I would not ever use them to many issues, high resistance etc...
Just keep screwing the screw in! That's what we had to do to dad's truck until the battery cable fairy took a new cable off dad's store shelf and replaced the cable! He asked me once if I knew why his truck still had gas in it, I then told him I rebuilt the carburator! He thought I wasn't putting gas in the tank, keeping the $ for myself. On a Sunday afternoon drive in the family car, we had a no start and a customer of dad jumped started the car and said John you need water in your battery! Guess who had to check dad's batteries after that!
