cardoza
I purchase my 1928 a few years ago, but it is now when I realized that the battery is connected negative to ground (as you can see, I rarely used the car) and now I am retaking the hobby and I have to replace the battery. (6 volts)
The question: what will happen if I reverse the connection (positive to ground)?
I cannot find any markings on the starter motor or generator that will indicate that they are negative to ground.
Was there any model A in 1928 built with negative to ground?
Any procedure to follow, indication, hint, or help, will be appreciated..thanks
