Basic data:
1940 Ford COE
1946-48 "59AB" V8 flathead engine
all original except for wiring completely redone and electric fuel pump and fuel regulator added,
6 volt, positive ground
Ran truck a few times and noticed it started cranking slower and slower with every start. Had trouble starting it once and ran battery down until it wouldn't crank. Recharged battery and tested across terminals and got about 5.7 volts. Got truck started and while running, tested battery across terminals and got about 5.7 volts no matter how fast engine was reved.
Started with generator: Tried to "motorize" it by taking it off the truck, jumping the field and armature terminals together, connecting negative battery terminal to jumped generator terminals and positive battery terminal to ground on the generator case. Generator barely moved. Opened it up and commutator coated in greasy film with all slots filled. Cleaned commutator, brushes (2), slots brushes ride in and put in new brush springs. Re-did "motorize" test and it spun nicely locked in a vise.
Reinstalled it in the truck without any wires connected to it just to spin it. Jumped the field and armeture terminals and connected a volt meter. Red lead to ground on generator case, black lead to jumped terminals. Started truck. Volts climbed to approx 6.25 then immediately killed engine. According to what I've read these tests show that the generator is mechanically OK and producing electricity.
Hooked everything back up, tested battery (5.7 volts) then started truck with meter on battery. Reved engine pretty high for a good 15-20 seconds but never got above 5.7 volts at battery. Figure its got to be the voltage regulator (of which I know squat). The one on the truck is a replacement. All I can make out on the faded cover is "Filko, Crown Jewels of Ignition". It has three connection points, ARM, FIELD and Batt.
After everything I've read, here is MY simplified understanding of the voltage regulator: The Batt (cut out) terminal says when and how long to run off the battery or when and how long to run off the generator/charge the battery. The ARM (voltage regulator) controls how many volts come from the generator and the FIELD (current regulator) controls how many amps come from the generator.
I connected a volt meter to the ARM terminal on the generator and ground to test the cut out as per a shop manual. Increased engine speed until I got 6.25+ volts then slowly decreased engine speed. Cut out points were supposed to open when voltage dropped to 4.2-4.8 volts but voltage never dropped below 5.7 volts? Could it be that engine is just idling too fast?
I don't have an amp meter so I can't test, according to the shop manual, the current regulator.
Phew!, OK, so here's my question: If I connect a volt meter to the Batt terminal and ground, then start and rev the engine and adjust the voltage regulator (at the ARM terminal) until I get 7.1-7.4 volts (got that from the shop manual) AND lower the idle speed, will I have solved my charging problem?
Yeah, I know, I can just get another voltage regulator but I'd like to keep what's there and I have no idea (amp size) which one to get.
1940 Ford COE
