Your getting a bunch of junk info. #1 DETERMINE THE POLARITY THE CAR IS SET UP FOR. From factory the A was positive ground, however lots of people convert them to negative ground. #2 Determine if the battery is charged correct polarity. Yes, it is possible to charge a battery backwards. Use a voltmeter to check, black to - post, red to + post. Do NOT connect battery to car until you know which polarity the car is set up to operate, and if your battery is charged correctly.
#3 does the car have the original generator and cutout? Keep in mind that a regulator can look like a cutout but will NOT put up with reverse polarity. If its the original cutout it will likely be fine.
#4 a good first indicator that the car has been converted to neg ground, is when you honk the horn, the ammeter jogs to the left. Also the coil will have a + sign (or red dot) by one terminal. If it is a negative ground car, that side of the coil should go to battery, positive ground car, the + side of coil will go to points in distributor.
#5 now that you've got the battery charged properly and the polarity of the car determined, now the generator needs to be polarized. Take a piece of wire and momentarily touch both sides of the cutout.
#5 start the car and verify that you get positive charge on ammeter.
