rdmace1956
The ground cable on the 49 had multiple issues so I was going for upgrade, Pulled the head bolt and got a geyser of coolant. Not as simple a swap as I thought. Tightened her back up for now.
I hate to ground to head bolt. But the old 6V starter needs the best chance it can get. Thought about getting a long cable to running it somewhere else on the engine. The ground strap stud is a bit far away, maybe a starter bolt would work. Need to look some more. I don't care about original on this one, but no desire to convert to 12 volt either.
41 mercury has the same modification. It is a stud and nut on the heads so a bit easier to deal with. Since that one is a 12 volt now it would probably work OK if I went back to original ground to firewall, I am trying to track down the way it was supposed to look.
I suspect Henry did it that way to make them easier to assemble but it was a crappy starter ground setup.
