Check the amp guage after shut down to make sure the cut out is not sticking and discharging the battery. When it has gone "flat" check the battery at the post with a volt meter. A bad connection on a cable can make it seem the battery is dead when it is not. Check make sure brake light switch is not sticking on. Check these and report back. We will go from there.
Hey Phil - thanks for your reply.
*Battery connections are good
*Brake light switch is not staying on
*Whilst on the trickle charger, the amp gauge sits on "0"
*When I crank it over, the amp gauge goes to -20 and just sits there
Does "crank it over" mean running? The ammeter shouldn't move during cranking except for a small amount showing the points opening and closing on most A's. If the ammeter sets on 0 with the engine off, but then goes to -20 with the engine running, then something must be wrong with the generator or cutout. With the belt removed from the generator, if you polarize it, does it spin slowly in the same direction that it normally runs?
Has anyone worked on the generator or cutout recently? Did this problem just start, but everything was fine before?
You say that as soon as the 'kill' switch[which I assume is an after market battery cut-out switch] is turned so as to allow the engine to start, the ammeter reads -20 even before the the ignition switch is turned on. Right ? If so, that means you have a huge draw somewhere in the electrical system. With a volt meter attached between the removed battery cable and terminal, either the - or +, really doesn't make much difference] read the voltage. it should be zero. If not, then keep disconnecting things until it does read zero and that'll be your problem. You can use the car's ammeter to quickly check the simple things like the brake light switch [most common problem] or cut-out, headlight switch etc.
