Any interest in new hybrid battery filler caps with the original raised Ford script and fine threads on the bottom to fit the new reproduction Ford Script batteries?
Larry, I will buy some caps when they are available.
Do you know if the new reproduction batteries meet Judging Standards with the proposed hybrid Filler caps or is there more to be altered? I'd be interested in your thoughts as I have a new battery ordered but was told it won't be correct.
That depends on the adjudicator's knowledge of what they are judging. As each year comes and goes, there are less knowledgeable judges.
Like Larry, I have pulled the prints of both the A-10720 Cap and the A-10660 Battery. When you compare the new repro battery to pix of original batteries, and to the factory prints, the repro can be camouflaged to resemble an original battery. I have set-up the repro case in the Bridgeport and used a flycutter to re-shape the exterior with success. Also, texturing the exterior is necessary to make it look more like rubber. The other issue with the reproduction battery is that the case is smaller in dimension. If the judge is knowledgeable, they will pick-up on this. This can be overcome but again, a lot more work. I was wrongly disqualified from a MARC event due to a weak repro battery that I had many hours in camouflaging and I had chosen not to do the same amount of work on a new battery. Right or wrong, I have a very bad taste in my mouth for batteries and unqualified judges.
Larry, great job on your caps!!
Thank you.
The battery I purchased from Jim's about 4 years ago is dead! I need a battery for Hamilton, any suggeations?
Thank you.
The last I knew they were out of production. I have a few dead ones also. My suggestion is to see if you can find a local battery rebuilder and have them refurbish your script battery.
Thank you.
I was able to finally reach someone at Jim's and they are still in business. Jim gave me a suggestion to restore my battery but it didn't help.
Battery Central Mall is showing them. I purchased one from them about 4 years ago. I could add one to the cart on their website tonight.
Yes, but not in stock. 5-8 months. I spoke to Wayne Cunningham, great guy. I had him put me on the order list. He did offer a fix for my dead Jim's. Call him and he should be able to hook you up.
