springerpete Well-known member Jun 2, 2018 #21 Seat riser here also and the switch breaks the ground not the hot side.
R rocket1 Well-known member Jun 3, 2018 #22 according to Ron Francis put the battery disconnect on the positive wire if you have any electronics in the circuit I guess like a C.B. or inverter,they could be damaged if you have a failure in a ground.page #104 Ron Francis catalog.
racingrufus Senior Member Jun 3, 2018 #23 Mine is on seat riser on ground cable. I have 12v neg. ground.
