So, IF your Model A is running you can switch the battery disconnect switch "OFF" if connceted to the ground side, and it will continue to run. IF you have a "KILL SWITCH" on the other cable you need to turn that to the "OFF" or "KILL" side to stop everything? Correct? Bob
Question: will placing the battery kill switch in the ground battery cable enable the Model A to continue running when the switch is opened (placed in the “OFF” or “KILL” position)?
Background & Observation: Attempting to hand crank and start a Model A without an installed battery has been (at least for me) unsuccessful.
Hypothesis: Interrupting the battery ground connection, whether by lifting the battery cable or placing a batter kill switch in the “OFF” or “KILL” position will cause the Model A to stop running.
Experiment: Start a Model A and interrupt (disconnect) the battery ground circuit and observe whether or not the Model A stops.
[There will be a momentary pause here while I stroll (rigorous scientific investigation cannot be rushed) to the garage and perform the above experiment…]
Results:
Test #1: Model A kept running with battery ground circuit interrupted (“open”)
Test #2: Model A kept running with battery ground circuit interrupted (“open”)
Test #3: Model A kept running with battery ground circuit interrupted (“open”)
Interim Conclusion: Hypothesis is false; interrupting the battery ground circuit on a running Model A will not “kill” the engine.
Retest (to observe the effects of opening the ungrounded battery connection):
Test #4: Model A kept running with ungrounded battery circuit interrupted (“open”)
Test #5: Model A kept running with ungrounded battery circuit interrupted (“open”)
Test #6: [Test #6 was interrupted by the Model A co-owner sticking her head into the garage and asking “What the heck are you doing with our Model A?” Sigh…]
Final Conclusion: Once the Model A is running, interrupting the battery circuit (whether grounded or ungrounded) will not cause the engine to stop (see Note 1). The purpose of a battery or “master” disconnect (kill) switch is to keep the automobile from being able to be started (or to provide an easy method of electrically safeing a vehicle while working on it), not to stop it once running.
Note 1: I'm probably the only Model A owner - engineer or not - who did not know this.
Note 2: This Model A is equipped with an alternator.
Sic transit gloria engineerus...
