Battery Disconnect Switch
Heavy flexible cables are available for welding and at marine supply stores. The marine stores also have reliable heavy duty battery cutoff switches. You will have to swedge the ends to the cables yourself. Tools are available to loan at the marine supply stores. The cable ends are also available at the marine supply stores. $$$
https://www.farmandfleet.com/products/036487-deka-battery-ground-strap.html
Farm & Fleet of course is a regional chain. I looked at TSC and Rural King but neither of them carry a multi-point ground strap.
This type of strap was OE on early '60s Corvairs, so you can buy it from a couple of Corvair parts dealers:
https://californiacorvairparts.com/battery/3267-battery-ground-strap-1961-64.html
Other than that I couldn't really find any examples, and it doesn't seem to be true that "any store catering to farms should have one."
OK. I guess it was a few years ago when I bought it. The marketplace seems to have changed. You can try a two-cable option with the same results. Just bolt the ends together at the frame.
