battery disconnect issue
Used to work on electric fork lifts and tractors used in flammable areas. We always disconnected the ground side first when changing battery packs or other components.
Once saw a pry bar blow like a fuse when dropped across the frame and battery post before the ground was disconnected. After seeing a demonstration of the power that can be stored in low voltage batteries, you will always remember -
GROUND SIDE FIRST.
