1940 Deluxe/Flathead V8. Replaced generator with MAC 40 amp alternator. Replaced headlights with halogen and running and stop lights with brighter bulbs.
1939/1940 Fords use dash voltmeters. Operation is fine during day but at night voltmeter goes into the red zone indicating discharge. I am not sure if it is a battery, alternator or short in the wiring. Previous owner disconnected hot water heater and clock light for some reason indicating an original problem. With everything off and the battery cutoff switch on a reading in the negative battery wire with a clamp on amp meter indicates 100 milli amps. This must indicate that somewhere in the negative side wiring is shorted to the frame before the switch to that circuit. Is there a means to check wiring before the switch to find short? Any suggestions?
