newshirt
Can any permanent damage occur if the battery is allowed to completely discharge through the ignition coil?
For me, this has happened accidently because I turn off the gas valve and allow the engine to use up all the fuel in the carb before putting it away for the night. I have, on occasion, walked away to attend other things and forgotten to remove the key from the ignition. Of course, the car runs fine after recharging the battery.
Last year, a "perfectly good" coil shorted and caused my points block to melt down. I believe two such battery drains had occurred that year, months before the meltdown. My new rule is to never leave the car without pulling the ignition key first. But I'm wondering if the internal insulation in that coil had been compromised by draining the battery through it. (Heat, no break in duty cycle.)
Are these just unfounded fears?
