So that would be the positive battery terminal which is grounded to the body - is where switch goes - right?
Green knob cut off should only go on the negative post of the battery. If you noticed it only fits the negative post. The positive battery post is larger and the only way you can make the green knob cut off switch work on that thermal is to spread it open. That's why there are two different sized thermals so you know the difference! Go figure!I had green knob cut off on positive side and it melted knob
Been using the the Cole Hersee switch. Best quality, believe they are still made in the USA at Cole Hersee in South Boston. Some favor switching the positive or hot side. NHRA or not, the best method is switching the ground. With the ground disconnected nothing happens anywhere, now how.
I have no idea why you would want to put the switch on the ground side. The "hot" side is where the switching goes.
"With the ground disconnected nothing happens anywhere, now how"
How would anything happen with the "hot" side disconnected? The ground comment makes no sense.
