No real need to disconnect the battery or pull the fuse, but many feel safer by doing it. If you use an alternator and leave it parked for some time then you may want to pull the fuse so you don't drain the battery.
I use a generator with an internal EVR and a cutout and don't ever disconnect the battery and I don't use a fuse. I can grab the battery cable and lift it off if I had to because it's just a slip fit.
I don't use a battery maintainer, but it's fine to use one for extended storage. I park the A in November, when the first salt hits the road, then I take it out in the spring after a couple good rains wash away any trace of salt. This can be a storage of 6 months, but the car fires right up. I'm still using the $2 battery I bought at the recycling yard 6 years ago.
