i was searcing posts but couldnt find an answer to my question. ......i am rewiring my 49 pickup and want to use original gauges. (6v to 12v) i know all about reducing the volts to keep the guages.....question is, the BATT meter,.... on my meter there is nothing to connect the "hot wire" to, just a loop to run it thru. from past posts guys say that no volt reducer is needed, ok no problem, soooo the wire that i run thru the loops, where do i connect the wire to if there is no terminals on the gauge? im going with a fuse block so i will not be using the stock breakers on the back of the guage panel......long story short, how do you wire the batt guage on a 49 going from 6v to 12v
