Funny you should talk about this...my 1930 [?] bumper clamps are
1~A rough casting. Not forged, not stamped and threaded. Chromed. Not stainless.
2~An odd size. 9/16" bolt shank and a appropriate thick nut.
3~The thread is a fine thread.
4~I measured one inch and counted 18 threads.
5~The dumb thing was I towed the 'A' home with a nylon strap and BLAM! Both of these clamps fractured and off came the bumper turning into my drive way.
6~Now I have to order two replacement bumper clamps.
7~In the mean time I'll bore out the center of the clamp [the broken 9/16" stud] to a 9/16" hole and purchase two flathead steel machine screws to go into a new counter sunk hole through the bumper clamp, through the backing, flat washer, lock washer, and screw into that thick 'special' nut. Screws need to be 2-1/4" long. There going to be tough to find.
8~'Cause they are cast, can't effectively weld them back together...I don't like cast bolts.
When I was in high school, a swim team member left the starting block with such force he blew the block clean off the edge of the pool and slamming it hard against the building wall. Yep each block was held down with two tee screws and a cast fat washer all one piece. The threads sheered off flush with the socket right under the cast fat washer screwed into a threaded pocket at the pools edge. And yes each bolt was a threaded casting.
The result is he lost balance and dived deep into the shallow end [starting end] of the pool and broke his neck. In a wheel chair for the rest of his life.
The next meet all bolts were steel machined screws. Not threaded cast crap.
So my question is were the original clamps threaded cast?
And should I go with costly cast chrome or cheaper stainless steel. Would the stainless still be cast as well?
OK I did something stupid again. skip.
"I think the original clamps were forged.
I have seen what appears to be cast reproductions that I would not want on my car.
Chris."
Thanks. I agree and think forged makes much more sense. Thanx. skip.
