barrel coil voltage 40 ford
lenmissy
changed coil to adapter put barrel coil on fender what should the voltage from the postive side to the points on 6volt coil be len
I have no idea what you are doing.If you are using a 12 volt battery to run your car, throw your 6 volt coil away.
Speedway sells coils with resisters set,or get a 12 volt coil and resister for a Ford 56 thur early 70s.
You can NOT use a 6 volt coil with 12 volts.
Why because a 6 volt coils needs about 3 amps and with a 1.5 ohm resister you will need 4 amps thur resister.They are made to handle 2 amps safely.Thats with putting 7 volts across coil and 6 across resister.
