fourbangerbob
I have 3 connecting rods plasti-gaged to .001 and connected. I can barely turn the crankshaft! Is that normal?
Thanks for all the good advice. I think .001 is to tight and the journals are not round. I will go for .001-75 and should free up---will let you all know----
Many times on an engine that has some use the rod journals may not be round anymore. This condition will give a false reading with plastigage. You may actually be tighter during part of the crank revolution. The same is true of the mains but I have not seen as much of a difference in main journal roundness as I have at the rod journals. Something to consider or check if you have not placed a micrometer on the journals. Solution...loosen them a bit.
Good Day!
Educate me! What is .001-75?
Closer to 0.002 than 0.001.
(heh - 0.0175)
Joe K
