Bruce/Texas
I have a banjo steering wheel that is well stuck onto the steering shaft. There are six 5/16 dia. bosses in the hub integral to the rather thin "spokes" on the inside of the hub. I could drill and tap these bosses for 3/16 (#10) bolts and use a gear puller but I think the 3/16 bolts will just pull out of the bosses when applying force to the puller.
Is the banjo hub aluminum? I wonder if applying some heat from a propane torch to the inside of the hub while applying moderate load to the gear puller would work. Would a little heat from the propane torch harm the steering wheel hub? Any suggestions?
Thanks in advance, Bruce.
