Banjo Shock Mounts
Aledo
Ill
Price
119.00
Pure Hot Rods answer to Henry's fluid shocks. We manufacture these MADE IN THE USA tube shock mounts that are an upgrade from the 48 Ford mounts. They are two inches longer and equal length with removable studs for custom applications. This allows for lowered cars to use an adequate shock length as well as being a great answer to a stock restoration. Hot Rodders and Restores alike have depleted the supply of original stock units, so here are bolt on, brand new mounts ready for your ride. We also offer the same mount that welds on any housing for that old school feel on your ground up build that is using a late model rear end, check our other listings. For $22 a pair, we offer stock type top shock studs. We are a full service Hot Rod shop specializing in Postwar Traditional Hot Rods. Any questions call Brian or Jake @ Pure Hot Rods (309) 582-3547
Do you have any pics showing an installed set up on a 32..shocks etc installed using your top and bottom mounts? Thanks, John
Same request as Slug! My thought is that there is not enough room on a 32-34 for your lower shock mount and the shock? Spring perch clearance & space between axle housing and spring?? I would like to use your mounts if they will fit a 32.
P.S. If you don't have a 32-34 rear end to check the fit, I have one and I could bring it up to Aledo. I'm in Morton. Call me. Jerry H has my phone number.
Steve Hayes
