The above link did not work for me. You can obtain the dissertation from the web site of the Santa Anita A's (Southern California)
www.santaanitaas.org. Click on technical, then on my name (Tom Endy).
Rear axle assembly bearings as far as I know are only made by Timken and they are expensive, over $300 per set, and they go up every year. The very early cars had the Ford logo on both the bearings and the races. Later cars used Bower bearings and races. Bearings and races were then supplied by Timken with the original Ford part number on them. Today Timken bearings and races use their own part numbers.
Contrary to popular belief, the seal in the outer end of the axle housings is not an oil seal, it is a grease seal. Its purpose is to keep grease pumped in through the grease fitting on the end of the axle housing from traveling down the axle toward the differential. Henry's design was such that grease pumped in through the fitting was blocked by the seal and forced to travel outward between the axle and the bearing hub. It then became trapped by the large seal in the brake drum and forced onto the large rear roller bearing. It was not Henry's best idea as before long the pathway becomes clogged with crud.
I have taken many rear axle assemblies apart and found both seals completely shot and where the owner had pumped a lot of grease in through the fitting and it had centrifuged down the axle half way to the differential . The build up could be an inch or more in diameter.
I have also taken units apart where the seals were intact or the owner had not pumped grease in through the fitting and found the axle shaft rusted with no sign of banjo oil any more than a few inches from the carrier. This tells me that oil from the banjo does not migrate out to the ends of the axle in normal service. I think the tapered design of the axle housing keeps the banjo oil where it belongs. Also the angle of the torque tube prevents oil that passes through the pinion bearings from going anywhere but back into the banjo. The same grease seal used in the axle housings is used at the front end of the torque tube and its purpose it to keep grease pumped in through the transmission rear bearing retainer grease fitting to grease the U-joint and roller bearing from migrating down the drive shaft.
The prudent thing to do when overhauling a Model A rear axle assembly it to replace all bearings, races, seals, and gaskets with new. However, I would try to use original rear wheel bearings with the spiral in the elements. They were well made and over engineered and if not rusted are good to use. The reproductions are hard on the surfaces of the axle housing hubs. I would also obtain the grease seals used in the brake drum from A&L, as they fit properly. Most other repos are too large.
Tom Endy
