I agree.. pressing it from the top is a better option.I tried it that way with a screw jack as shown in the vern Tardel book and it warped the housing out of round. I ended up buying a cheap hydraulic press and borrowed an exhaust fitting/press tool from local shop to press it out. I then was able to use the press and re shape the housing back round.
Build a "bridge" thru the housing like in the picture and press it off the pinion without loading the housing. Shouldn't need heat with an adequate press.
