Banjo Differential Spool
bco175
New member
I want to make a RIGHT ANGLE GEAR BOX out of an old banjo rear axle. I'll use it to go from linear input (chain drive) to rotary final drive (drive shaft) . To do this , it needs to be a locker . I would like to do this without welding the spiders. Did anyone ever make a spool for this style rear end? Going to use this on a GOULDCAR syle application.
This is the "to the editors" "test forum. A place to come and test functions on the site such as posting pictures. You need the general discussion section under the year of the banjo you have on hand.
