Leoneidas
When I first mentioned that I would be putting a Model B cylinder head on my A block, many asked why? And that was a very good question.
Well, one guy brought up a good point about steam holes needing to be blocked off, which I hadn't done and assumed that this is what has been causing my overheating issues since replacement. I had 98% ruled out the radiator being the issue since I had it cleaned by an old school radiator man.
Just the other day I pulled the trigger on a Snyder's 6:1 head and leakless water pump and installed with the proper head gasket studs and an aluminum 2 blade fan that I had. Torqued the head, timed the engine and ran it for 20min to produce a heat cycle. The next morning I torqued the head nuts again and went for a short drive. The water temp gauge never moved. I used my DVOM when I returned home to check the water temp and it was only at 150F, which is good news but now I have to check the function of the possibly bad new temp gauge.
It's been super cold and icy here in SC the past few days but I will spend the next week confirming that the overheating issue has been fixed.
All of this to say, keep it simple stupid, especially when the common swap produces much better results. Was definitely a learning experience but now I should be able to enjoy my car a little more. Anybody looking for a complete head and water pump replacement for their Model B engine?
I don't seem to be able to upload videos for some reason. Any help with that would be greatly appreciated.
