Don, this isn't a sales pitch but using a used hub to balance a tire might be the cheap way to do the job its not very accurate. The tire and wheel are balanced including the out of balance weight of the used drum. When you take the assembly off and install it on another drum the balance is now effected by the weight of that drum assembly, so unless you are one lucky guy the wheel and tire are now out of balance again.
