Old Henry
Even Ft. Wayne clutches need balancing.
The left clutch is the one I just took out of my car that was put in a couple of years ago when I had my entire engine balanced by the local racing machinist. He balanced the clutch with those dollops of weld on the two flanges, the left one ground off a bit after applying to get it perfectly balanced.
The right one is the one I just got new from Ft. Wayne and also needed that washer welded on and some ground off on the opposite side to balance it.
