franksford
I'm getting ready for new rubber on my 36. Do i need an adaptor for modern balancers and if so, who has them. Thank you.
Frank
Frank
Is this a balanced adapter or should it be balanced first before using it to do individual wheel/tire combinations? I use an aluminum wide five racing adapter and was surprised how out of balance it was. I had to make a plate with a small bearing to insert into the adapter center to get it in balance first.
I run beads in my 39 had nothing but trouble getting rims balanced but with the beads great [be warned they are a pain in the backside to get them into the tubes but worth the effort ]
IMO take the car to a shop who can balance the tires on the car , he will first shave the tires to make them round , then balance on car , then mark tire rim and to drum in case you ever dismantle
