oriondal
Hi guys,
I was driving the A and it started knocking a bit then quit and wouldn't restart. A quick inspection show the distributor rotor wasn't turning. I removed it and the lower distributor shaft, and the gear at the bottom isn't turning with the engine. Does this sound like it might be a bad timing gear? I haven't had the chance to remove the valve chamber cover, but I guess that's the next step. If it turns out to be the timing gear, I see they sell both aluminum and fiber gears with the fiber available in standard, .03 oversized and .05 oversized. They're all about $50, any suggestions which might work best?
Thanks
Thanks
