When working on the Model A engine there is no other worse feeling than going for 55 ft-lbs and feeling the torque wrench start to "cave in on you"! I recently purchased a Model A and about a month after I had it, the crankcase got a lot of water in it. I had a heck of a time getting the head off of the engine and found that who whoever rebuilt it, had two improperly drilled Helicoils which resulted in two leaning studs. I like John Charlton's idea of bending a stud but John wasn't at my house when I needed him! I felt that the engine had been together so it had to go back together the way was. I put all the good studs into the block. I put on the head gasket and the cylinder head on the block. Then using NeverSeize, I installed the two troublesome studs using a single nut threaded on half way and a spare stud threaded into the other half of the nut to stop any turning. When the studs hit the top of the hole in the block, the treads are lined up enough to start OK, it is only as the stud gets deeper that there is more and more interference with the stud and the upper area of the cylinder head. This is where the NeverSeize comes into play, all of the stud was coated and I was surprised that with the wrench on the nut and the spare stud on top of the nut, locking the assembly together, I could turn the stud down into the Helicoil to the required depth. I know this isn't the best but who wants to pull the engine and take it to a machine shop for correction. I worked for me and everything torqued down just fine to 55 ft-lbs. After 1000 miles there is no water leakage. Ed
