Good news is the gauge and wiring is OK. The other news is your testing by grounding was only a few seconds as advised by "drolston". The better news is you avoided a fun trip under the dash.
Your car should have a 81A-6049 head on the right side and a 81A-6050 head on the left side as they have different combustion chamber volumes to match the different valve angles. However this has nothing to do with temp sensing as your car and all 1940 and '41 Fords had only one temp sensor. Even a deluxe or a super-duper deluxe would have only one sensor and it was mounted onto the left head. The outlet for the right head would be plugged if no heater was fitted.
The right side head is not original to your car.
Original King -Seely OEM sensors will be marked with a "KS" stamped on the hex head and the body of the sensor will not be cylindrical but will have a couple of grooves in it as shown in reply #8.
I have redrawn the crude temperature chart for the gauge and it is shown below. I have rerun the test with another K-S sender and the results are identical, showing how precise these instruments are.
The short hash marks on the gauge are at 150 F on the left side and 200 F on the right side. Note that 200F is still within the standard operating range according to Ford. They go on to say that going above that is OK for severe conditions and overheating does not occur until there is actual boiling. The gauge will show "boiling" when it hits the right side marker line labelled "H"
I have also included the pages from the 1940 owners manual with the text about the "Heat indicator".
Keep us posted and let us know if the faulty sender unit is a real K-S or not.
