Purdy Swoft
Lots of things can go wrong with electronic ignition that will leave the model A dead, side of the road or in the road. Most that run electronic carry an original timed distributor for when the electronic setup fails. Most don't really trust electronic but peer pressure often causes them to try and use it. Same with V8 points setup. Its really the modern setup that causes the problem, foreign parts and parts that were not designed for the model A distributor. I really can't understand why so many think that such a make shift set up is SO cool. The only time that I couldn't make it home with the original style points setup was when the rubbing block came off of the old JC Whitney points and that was over 20 years ago. Good original style points and condensers are available from most model A vendors. I've run the same original style points and condenser in my 31 sedan for 13-14 years. Good luck
