'31 Patina
I have a '31 coupe with the stock transmission and clutch. I can no longer get the car into any gear and I'm thinking I need to drop the transmission so I can get to the clutch and see what's going on.
Yesterday I removed the inspection plate that sits on top of the bell housing and with the car running I could see the pressure plate spinning. When I pushed the clutch pedal in the pressure plate keeps spinning so the clutch won't engage and let me shift into any gear.
Do I need to adjust the fingers on the pressure plate? There are six nuts on the pressure plate that look like they could be adjusted? When I push the clutch in the throw out bearing moves freely but it doesn't even come close to contacting the fingers on the pressure plate.
I do have a Les Andrews book and before I decide to remove the transmission from the car to inspect the clutch, is there anything else I should be checking or is there a way to adjust the fingers?
Thanks!
Thanks!
