oldspert
I pulled my engine to check the clutch because I had to nearly push the pedal through the floor to get it to release. Upon checking I think a new clutch had been installed. The disk looks like it is brand new, so at some time in the past a new disk had been installed. I don't think the person knew how to adjust the fingers because they were not the same height by over nearly 1/8 of an inch and worn unevenly. The bolts are not graded bolts, if that makes a difference. So a new pressure plate is going in with a new throwout bearing, just in case. The flywheel looks like it was re-surfaced or maybe it is a new one. I can't find any slippage in the pedal linkage so maybe that is OK, the release arm is not cracked as far as I can tell.
Ed
Ed
