edhd58
Okay, I know part of this is may be my fault.
I just want to know if I am thinking along the right lines to fix it.
The clutch in my 42, G 6 cylinder, has shuddered or chattered or whatever you want to call it almost from the day I got it all back together.
I either got some grease on the flywheel, Or the leaking rear main allowed oil to get on the disc.
I got the clutch and flywheel off the engine tonight and there is some bluing from me slipping the clutch to make a smoother exit from a stop light.
You can still see ALL the flycutter patterns from the machine shop resurfacing the flywheel when the motor was rebuilt.
I am thinking I just need to go ahead and have it resurfaced again, put in a new clutch disc and pressure plate. they all have less than 500 miles, probably closer to 200.
OR, can i have the pressure plate resurfaced?? i know its a new disc no matter what.
By the way, yes I am going to redo the main seals, I know what I did wrong there but I have a question about the rope seal prep.
