After buying my 29 in a non running state, I finally got it started yesterday. I had a few problems keeping it running and I hope I didn't over rev it after starting it up, racing the engine and then running around to catch the throttle linkage before it stalled.
Anyhow, today I had a chance to get things a little sorted out. I got the carb to idle. In fact, I got it to idle at around 200 rpms. just putting.
However, now I hear a metalic sound a clicking or rattling. It kind of goes put-put-put-rattle-put-put-put-rattle.
I've used my long screwdriver, stethoscope method of listening to the internals, and I can't hear it that way. I've listened to the cylinders, valve cover, water pump, oil pan, etc and all sound like a little engine working away. But then when I get away from the engine I hear that metal sound.
I'm worried about the crank. Would the sound be consistent if there was a bad bearing/babbit or would it be intermediate? Any guess as to what it could be, and how bad it could be?
I did have the head off and all looked fine there. If you A Model gurus can diagnose the problem from my description, you are good...real good!
I did have
I did have
