Kevin in NJ
Reading through the Tech Q&A and bad advice prevails. Who is this Dave Bockman and is he on this board?
The question was about synthetic oil and is it good for the A.
Dave spends several paragraphs talking about the A needing the 1200ppm of ZDDP.
The ZDDP at 1200ppm is only needed in the high performance engines. Oil currently has ZDDP at the 1950's levels.
He does not talk about the need for additives to prevent bad chemicals which is critical to our cars which are not driven much.
Then the guy asking about straigtening wheels. He does not tell the guy factory specs for a straight wheel nor about using heat shrinking to correct the problems.
Both these items are covered in good detail on this forum.
Please do not get me wrong, I know the guy is stepping up to the plate here to help. But where is the editorial process that catches these errors?
